    Field of View Settings
    3 Posts 2 Posters 2.6k Views 2 Watching
    • R
      rhankc
      I have been sending interior shots of my model to jpg and inserting them in cad drawings. i find that each time I define a view I have to redefine the SU Field of View. Is there a place to set the interior field of view at 60 DEG permanently rather than the default 30 DEG?
      Thanks,
      Hank
      • Jean LemireJ
        Jean Lemire
        Hi Hank, hi folks.
        Start SU. This will load a template. Change your field of view and then immediately save the file as the same template in the same location.
        The next time you will start SU, it shall load this template with your favorite field of view.
        Just ideas.
        • R
          rhankc
          Jean Lemire,
          And a very good idea too! I will add that if you don't hit a carriage return after entering the new view angle the angle doesn't apply. thanks for the advice, it worked!
          Hank
