    Vector.angle_between() -- Direction?
    8 Posts 4 Posters 3.4k Views 4 Watching
    • daikuD Offline
      daiku
      I'm trying to rotate a comp inst so that it is parallel to the green axis. I have a vector that represents the component, and I use that vector's angle_between method to create a (rotation) transformation object to apply to my comp inst. It works right most of the time, but sometimes, it rotates in the wrong direction. It seems that angle_between never returns a negative value, even if I want to rotate in a "backwards" direction. Is there a better way to find the angle? Thanks, CB.
      Clark Bremer
      http://www.northernlightstimberframing.com
      • Didier BurD Offline
        Didier Bur
        The angle_between method returns a value between 0 and PI, so 270° is the same for it than PI/2 😢
        This is really a weird way of returning angle IMHO 8O
        Nobody knows (at least not me) why 'they' coded this that way.
        I'm afraid you'll have to test the two vectors to know in which trigonometric quadrant (0°->90°,90°->180°,180°->270°,270°->360°) they are, to get the "real" angle between them.
        But perhaps you could also use this:
        your_component_instance.transformation.yaxis = your_angle
        Hope this helps 😕
        DB
        • daikuD Offline
          daiku
          Thanks, DB, that helps a lot.
          I just changed my code to try using the angle_between angle, and then check the result to see if it's where I expect it to be. If not, then I reverse the angle, and try again. Lots of code, but correct behavior now! Thanks again. CB.
          Clark Bremer
            RickW
            I created a vector1.flat_angle(vector2) method that does this work for you.
            RickW
            www.smustard.com
              Didier Bur
              Where's this gem, Rick ? I don't see it at smustard 😲
              DB
                If you have pathcopy.rb you get vector.flat_angle.rb...
                  Didier Bur
                  OK OK OK 😳
                  Thanks for answering., have a nice day 😛
                  DB
                    RickW
                    Yeah, sorry about that. I suppose I shoul give it its own spot for developer use 😄
                    RickW
                    www.smustard.com
