    [Plugin] VolumeCalculator v1.8
    5 Posts 4 Posters 7.5k Views 4 Watching
    • TIGT
      Here's v1.8. For some reason it's just started to Bugsplat on my new PC (Vista). It didn't before ! This new version avoids a splat since it has a two step undo. The splat seems to come from after it's intersected the volume slicing disc group to make entities inside another vol group and then it is trying to erase that disc group within the same commit/undo as the rest. By making 2 undo steps it doesn't splat - go figure ? PayPalButton
      VolumeCalculator.rb
      • ToboboT
        Tobobo
        Toby
        Philippians 4:13
        • AdamBA
          AdamB
          This all seems quite a complex way of getting the volume.. The following analytic approach works nicely.
          def calculateVolume(container)
          	volume = 0
          	for face in container
          		next unless face.kind_of? Sketchup;;Face
          		volume += (2 * face.area * (face.vertices[0].position.dot face.normal)) / 6
          	volume
          • AdamBA
            AdamB
            Doh. And you need to have Geom::Point3d#dot defined - (which is beyond me why it isn't as standard)
            class Geom;;Point3d
            	def dot(v)
            		self.x * v.x + self.y * v.y + self.z * v.z
            • Dan RathbunD
              Dan Rathbun
              I have posted my rendition of the "no temporary group" calculate volume solution.
              See: Calculate volume on manifold surface without group & explode
              Bonus method for a volume display string in model units:
              See: [code] format volume in model units
              I'm not here much anymore.
