    [Plugin] Self Paced Tutorial Assitant
    8 Posts 8 Posters 8.3k Views 8 Watching
      Jim
      Here is a little script to help tutorial makers lives easier.
      It copies the selected geometry along the x-axis, moves the camera the same distance, and finally adds a new scene to save the view.
      It will create a first scene if none exists on first use.
      It creates a menu item called "SPT Copy" in the Plugins menu. Use a shortcut to activate it quickly.
      sptm.rb
        Jim, this is very kind of you - thanks (I make tuts "once in a while")-
        Also, by default I don't have "scenes" turned on so this would save a couple of steps for sure!
        • TaffGochT Offline
          TaffGoch
          Thanks for the script, Jim. I can envisage the potential convenience.
          I'll give it a test run...
          Regards,
          Taff
          "Information is not knowledge." -- Albert Einstein
            Thank you Jim. This should be really handy.
              RickW
              Sounds like AddPages but with an added geometry copier. 😄
              RickW
              www.smustard.com
                dylan
                Thanks Jim, very useful indeed.
                http://dmdarchitecture.co.uk/
                • E Offline
                  ECOTTechTchr
                  Does this plug-in work in SketchUp 8? When I tried to install it from Window > Preferences > Extensions > "Install Extension", it won't recognize the file because it's .rb rather than .rbz.
                  Thanks!
                  • cottyC Offline
                    cotty
                    Thanks!
                    plugins with .rb are no extensions and you only need to copy it in the right directory.
                    More details from Thomthom...
                    my SketchUp gallery
