    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin] SectionCutFace v2.0
    65 Posts 23 Posters 67.4k Views 23 Watching
      @burgz4 said:
      Hi, no luck with the zorro 2 am i doing it wrong there is nothing there to download . I need the actual link to the down load and how to down load in simple terms.
      thanks
      πŸ˜•
      There are two files to download - they have links on that page for Zorro2 that I linked directly to earlier - one is the ruby script [.rb] the other is a .pdf tutorial - they are found just below the large image ???
      How is your session set up ?
      Assuming you can see these two file links, then depending on your browser clicking on them should open a dialog that asks if you want to open or download them etc.
      On Yes/OK for download/save them to your desktop.
      From there move/copy them to your ..Sketchup../Plugins/ folder.
      On restarting SUp there should be a new Menu item - Tools > Zorro ... and also some right-click context-menu items.
      Read the Zorro2 PDF help file on how it works...
      NOTE: sometimes scripts come in multiple files found inside a zip file, which can be downloaded and then needs extracting - the resulting files/sub-folders etc need to go into Plugins, BUT in this case the 'plain' .rb file is all that is needed and that goes straight into the Plugins folder with not modification...
      Most plugins load into the Plugins Menu but in Zorro's case it loads into the Tools Menu...
      πŸ€“
        cstadler
        Hey TIG,
        where can I download your Plugin?
        Cheers,
        chris
        • massimoM Offline
          massimo Moderator
          At the bottom of the first post of this thread...Oh and welcome. πŸ˜„
            cstadler
            Thanks!!!
              There is a new version 2.4 available here - http://forums.sketchucation.com/viewtopic.php?p=172583#p172583
              Please use this...
              • 4 / 4
