Entertainment Center
Attached is an entertainment center typically used for a small, bookshelf stereo system or a component system.
[attachment=1:u53hkbbn]<!-- ia1 -->ent_center.jpg<!-- ia1 -->[/attachment:u53hkbbn]
[attachment=0:u53hkbbn]<!-- ia0 -->ent_ctr.skp<!-- ia0 -->[/attachment:u53hkbbn] -
Nice design. Clean and simple.
Look at your curved edges on the top and bottom however. There is some strange geometry going on.
Yeah, I fixed that. Also reversed faces (attached "version"). Nice design, truely. Thanks for sharing.
ent_ctr.skp
I wonder however why the file size grew that considerably?! I didn't add anything - as a matter of fact, there are about a dozen lines less in the geometry. -
Gaius,
I ran a "purge all" and the file dropped to 87 KB. There was one style not being used - the styles can very quickly bloat your models - even to the point of not being usable. The Purge All Script is available here http://forum.sketchup.com/showthread.php?t=78887&highlight=Purge+All
Written by TIG and it rocks so hard - you don't even know. Thanks again TIG!
ent_ctr[2].skpposter-Shaun Tennant
Sure I didn't purge anything at all and didn't check styles either (actually I don't use styles too much therefore I'm never too much aware of them).
Thanks for the tip though!
I don't know how that happened. I originally drew it in AutoCAD and brought it into SketchUp. Must be a CAD thing. I need to learn more about this stuff.
Is there anyone out there that also uses AutoCAD to draw the geometry?
Register LoginAdvertisement
