    Entertainment Center
    6 Posts 4 Posters 1.1k Views 4 Watching
    • cadmastrC Offline
      cadmastr
      Attached is an entertainment center typically used for a small, bookshelf stereo system or a component system.
      [attachment=1:u53hkbbn]<!-- ia1 -->ent_center.jpg<!-- ia1 -->[/attachment:u53hkbbn]
      [attachment=0:u53hkbbn]<!-- ia0 -->ent_ctr.skp<!-- ia0 -->[/attachment:u53hkbbn]
      Chris Picciano
      Website: http://www.chrispicciano.com/3dmodels
      • boofredlayB Offline
        boofredlay
        Nice design. Clean and simple.
        Look at your curved edges on the top and bottom however. There is some strange geometry going on.
          Yeah, I fixed that. Also reversed faces (attached "version"). Nice design, truely. Thanks for sharing.
          ent_ctr.skp
          I wonder however why the file size grew that considerably?! I didn't add anything - as a matter of fact, there are about a dozen lines less in the geometry.
            Shaun Tennant
            Gaius,
            I ran a "purge all" and the file dropped to 87 KB. There was one style not being used - the styles can very quickly bloat your models - even to the point of not being usable. The Purge All Script is available here http://forum.sketchup.com/showthread.php?t=78887&highlight=Purge+All
            Written by TIG and it rocks so hard - you don't even know. Thanks again TIG!
            ent_ctr[2].skp
            poster-Shaun Tennant
            Whether they find a life there or not, I think Jupiter should be called an enemy planet.
            • Jack Handey
              Sure I didn't purge anything at all and didn't check styles either (actually I don't use styles too much therefore I'm never too much aware of them).
              Thanks for the tip though!
              • cadmastrC Offline
                cadmastr
                I don't know how that happened. I originally drew it in AutoCAD and brought it into SketchUp. Must be a CAD thing. I need to learn more about this stuff.
                Is there anyone out there that also uses AutoCAD to draw the geometry?
                Chris Picciano
