    [Tutorial] Quick octahedron
    6 Posts 4 Posters 2.9k Views 4 Watching
    • Jean LemireJ
      Jean Lemire
      Hi folks.
      See attached SU file.
      Of course the fastest way is to import the existing component but it may need rotations to reorient it.
      Quick octahedron.skp
      • S
        SchreiberBike
        That works nicely, but I was confused by the text. You refer to circles. All I see are squares.
        • N
          namza
          Jean Lemire use a "Horizontal circle with four segments" ( look at the file )insteadd a simple square : with a 4 segments circle instead a simple square you are able to use the center of the cerle.
          • S
            SchreiberBike
            Ahh, of course.
            • G
              Gidon Yuval
              Oh My God!!
              Using a 4 sided circle instead of a square so as to be able to use the "point at center" function is absolutely brilliant!
              Jean is a true master!
              (Gidon)
              If you don't know where you're going, you're never going to get there.
              • Jean LemireJ
                Jean Lemire
                Hi folks.
                In my tutorial, if you use the Polygon Tool instead of the Circle Tool, you will save the unsmoothing step.
                So it becomes a very quick octahedron drawing.
                Just ideas.
