    [Tutorial] Mirror Script - How To Use and Top Tips
    2 Posts 2 Posters 3.1k Views 2 Watching
    • H
      Howard leslie
      See attached jpg
      Mirror Script - definitely one of the most useful Scripts around. (Thank you TIG).
      Download from Didier's excellent website here:
      http://www.crai.archi.fr/RubyLibraryDepot/Ruby/Ruby_links.html
      Usage:
      Yes, you can use 1,2 or 3 points.
      My Top Tip would be, always use 3 points.
      (certainly until you get used to using the script).
      That way results are more predictable.
      Just imagine where you would have to place a real mirror to get the desired result you want.
      Then go and click on 3 corners of that Mirror and Voila, geometry is perfectly mirrored.
      You don't need to actually draw the mirror as I've shown in the example !!! - just click the 3 points.
      Howard L'
      • KrisidiousK
        Krisidious
        thank you Howard...
        By: Kristoff Rand
