    [Tutorial > Modeling] blocks landslide using SketchyPhysics
    6 Posts 4 Posters 4.3k Views 4 Watching
    • N
      namza
      using sketchyphysics and saving the file just afer "playing " the physics rules ( wait until all the blocs stop to move).
      sorry if this trick is well known...
      blocks arent intersecting together
      use this with sketchyphysics
      blocks_end.skp
      • J
        Jackson
        Namza,
        It doesn't matter if it's well known or not, it's a neat trick and you're the first to post it here so thanks!
        I edited your subject title so it's a bit easier to understand and find.
        Thanks again,
        Jackson
        • GaieusG
          Namza, if you don't mind, I'm moving your post to the Tutorials > Plugins... > Sketchy Physics section.
          • N
            namza
            its not realy a physics tutorial ( nothing to do execept putting blocks and waiting they fall)...its a way of modeling using this plugg. People who arent interrested by playing with sketchyphysics can be interrested bye using it as i propose.
            • GaieusG
              Moved back...
              • M
                Masta Squidge
                Wow thanks much, I cant believe I hadnt thought of doing this... I made a couple models where I positioned each and every object by hand.
                That way took hours, this way takes minutes.
                See here the result of a grossly overloaded pallet when combined with a grossly under-intelligent employee.
                Mind you the pallet jack had to be positioned by hand, Sketchy Physics' object types do not allow the entire model to be used as a single object (unless used as a static mesh, which wont work here), leading to VERY odd things happening when placed underneath and through the slats on the pallet. This can be worked around, but I did this in a few minutes time.
                Thanks for the tip! Truck and pallet jack found on warehouse.
