    Styles Oddity
    10 Posts 6 Posters 2.3k Views 6 Watching
    • boofredlayB Offline
      boofredlay
      I downloaded some styles from chris71 in the Original SketchUp Forum last night. I placed them in a New Styles folder in the Styles folder along with a bunch more I have been collecting. While they work there is a problem.
      Here is a link a thread I replied to:
      http://forum.sketchup.com/showthread.php?t=81905
      Just in case the link goes dead here is my reply with the problem.
      I am experiencing some trouble with your styles. When I load SU if I pick on wet-watercolor it is fine. Then I try Dots and it stays with the watercolor. I try Urbiaco and again it stays with the watercolor.
      On the flip side if I reload SU and start with dots then try wet-watercolor, it stays with dots etc...
      I can use any of the other styles fine it is just with yours.
      Hmmmm.
      The styles I downloaded were:
      wet-watercolor
      Urbiaco
      FatCrayon
      Dots
      If anybody knows what is causing this please share.
      • RonSR Offline
        RonS
        Eric,
        Make a real small change to the style and save it as a style and rename it. Then it should work right.
        Design is not just what it looks like and feels like. Design is how it works.
        Steve Jobs
        RonS
          boofredlay
          Thanks for the reply Ron but how do I make a change? And what should I change so I don't mess it up?
          I tried opening it in Notepad but I just saw a ton of code. I have never played with making new or editing styles.
            Eric, make changes in the style box -> edit tab. You can play around there with the settings.
              boofredlay
              Oh it is that simple huah? I thought Ron was talking about changing some code. Thanks Guys.
              • RonSR Offline
                RonS
                Sorry. 😒 I should have said settings.
                Steve Jobs
                RonS
                • EdsonE Offline
                  Edson
                  I would not mind if some generous soul decided to share a couple of styles with the rest of us. not at all.
                  regards.
                  edson
                  http://www.mahfuz.arq.br
                  • N Offline
                    not registered yet
                    Hi, I'm the author of the "buggy" styles, is my first post here.
                    I know the problem of these styles, but I don't know how to avoid it. I tried the last suggestions about saving the styles with a new name but for me it didn't work, I have always the problem: the first of my styles I choose is the only I can see in the document.
                    If somebody find the solution, I'will be glad if he can post here the styles corrected.
                    Thanks, and I'm happy to have found a new refernce forum about sketchup!
                    [chris71]
                      boofredlay
                      Glad you are here Chris. I have enjoyed your styles. Hope they get sorted out. I see you saw the post Ross gave you on the SketchUp Forum.
                        shoreline99
                        Yes, thanks for those styles Chris. I hope you continue to create these as they are very useful!
                        Thanks again!
