    Bezier and Spline curve - A favor for German translation
    6 Posts 3 Posters 1.5k Views 3 Watching
    • fredo6F Offline
      fredo6
      Grüssen to all members of this German forum on Sketchup.
      I am in the process of publishing a new version of Bezier curves, with a number of evolutions and enhancements, including new types of curve. This is a macro called bezierspline.rb. I published a complete beta on the forum at:http://www.sketchucation.com/scf/viewtopic.php?f=9&t=3633, along with a tutorial and instructions for usage.
      At the moment, the macro only support English and French. As I am respectful of other languages, I was wondering if any kind member of this section could take the time to translate the strings into German.
      I have separated these strings in the attached text file bzstring.txt. The method to insert the German translation is fairly simple.
      Say that you have the following constant:
      BZMNU_EditMenu = ["Edit",
                        "|FR|Editer"]
      Then you insert the German translation as a new string in the array, with |DE| in front.
                        "|FR|Editer",
                        "|DE|Aufbereiten"]
      Note: I recommend you put a backslash in front of special characters (like \ü), as Ruby has sometimes a problem to read them.
      Thanks very much in advance for your help.
      Fredo
      404 Not Found
      (sketchucation.com)
      • eevaE Offline
        eeva
        macht das jemand?
        • FormalyKnownAsMartinF Offline
          Ich setze mich heute Abend mal dran - wenn niemand was dagegen hat!?
          Martin Habes
          • eevaE Offline
            eeva
            ich habe definitiv nichts dagegen, denn ich habe mit dem transfer genug zu tun 😉
              Moin.
              Ich poste das noch im alten Forum, da dieser Thread ja irgendwie hier auch abgeschlossen werden muss 😉. Ansonsten bin ich schon umgezogen.
              Im Anhang die Übesetzung.
              Vielleicht kann sie noch mal jemand redigieren bevor sie auf die deutschsprachigen User losgelassen wird.
              bzstring-de.txt
              Martin Habes
              • fredo6F Offline
                fredo6
                Martin,
                Thanks very much.
                This works perfekt, i.e. as far as my poor German can recognize, but I am sure you found the right terms. And it took me 2 minutes to integrate.
                So, Viele Danke
                Fred
