Bezier and Spline curve - A favor for German translation
Grüssen to all members of this German forum on Sketchup.
I am in the process of publishing a new version of Bezier curves, with a number of evolutions and enhancements, including new types of curve. This is a macro called bezierspline.rb. I published a complete beta on the forum at:http://www.sketchucation.com/scf/viewtopic.php?f=9&t=3633 , along with a tutorial and instructions for usage.
At the moment, the macro only support English and French. As I am respectful of other languages, I was wondering if any kind member of this section could take the time to translate the strings into German.
I have separated these strings in the attached text file bzstring.txt. The method to insert the German translation is fairly simple.
Say that you have the following constant:
BZMNU_EditMenu = ["Edit", "|FR|Editer"]
Then you insert the German translation as a new string in the array, with |DE| in front.
BZMNU_EditMenu = ["Edit", "|FR|Editer", "|DE|Aufbereiten"]
Note: I recommend you put a backslash in front of special characters (like \ü), as Ruby has sometimes a problem to read them.
Thanks very much in advance for your help.
http://sketchucation.com/forums/scf/sas/Deutsch/bzstring.txt
macht das jemand?
Ich setze mich heute Abend mal dran - wenn niemand was dagegen hat!?
ich habe definitiv nichts dagegen, denn ich habe mit dem transfer genug zu tun
Moin.
Ich poste das noch im alten Forum, da dieser Thread ja irgendwie hier auch abgeschlossen werden muss. Ansonsten bin ich schon umgezogen.
Im Anhang die Übesetzung.
Vielleicht kann sie noch mal jemand redigieren bevor sie auf die deutschsprachigen User losgelassen wird. -
Martin,
Thanks very much.
This works perfekt, i.e. as far as my poor German can recognize, but I am sure you found the right terms. And it took me 2 minutes to integrate.So, Viele Danke
Fred
