    Bezier and Spline curve - A favor for Portuguese translation
    Scheduled Pinned Locked Moved Português
    3 Posts 2 Posters 9.7k Views 2 Watching
    • fredo6F
      fredo6
      Hello to all members of this Portuguese forum on Sketchup.
      I am in the process of publishing a new version of Bezier curves, with a number of evolutions and enhancements, including new types of curves. This is a macro called bezierspline.rb. I published a complete beta on the forum at:http://www.sketchucation.com/scf/viewtopic.php?f=9&t=3633, along with a tutorial and instructions for usage.
      At the moment, the macro only support English and French. As I am respectful of other languages, I was wondering if any kind member of this section could take the time to translate the strings into Portuguese, as there seems to be a quite active Skecthup Community there.
      I have separated these strings in the attached text file bzstring.txt. The method to insert the Portuguese translation is fairly simple.
      Say that you have the following constant:
      BZMNU_EditMenu = ["Edit",
                        "|FR|Editer"]
      Then you insert the Hungarian translation as a new string in the array, with |PT| in front.
                        "|FR|Editer",
                        "|HU|Editar"]
      Note: I recommend you put a backslash in front of special characters (like \õ), as Ruby has sometimes a problem to read them.
      Thanks very much in advance for your help
      As you can guess, I am not so fluent in many languages, so I have to ask support from the International Community
      Fredo
      bzstring.txt
      • EdsonE
        Edson
        hi fred,
        i can do it for you, provided you are not in a hurry.
        http://www.mahfuz.arq.br
        • fredo6F
          fredo6
          Thanks Edson, very kind of you
          No hurry. I need a few more weeks to get feedback on bugs and wishes, and also to make sure it works on Mac (not easy I don't have a Mac myself). I may also add NURBS to the set of supported algorithms.
          Fredo
