RPS3D PDF Version 2.0 released
A new version of RPS 3D PDF - Version 2.0 has been released.
You can download it from the download area: http://www.renderplus.com/pdf/download.htm Downloads
This version uses a new method create the PDF background, and now supports a much larger variety of fonts and sizes. Also, this version allows you to create batch files to automate the creation of 3D PDFs.
Note: If you purchased RPS 3D PDF prior to Jan 1, 2007 you will need to upgrade your license to use the new version.
See: http://forums.renderplus.com/wiki/index.php?title=RPS_3D_PDF_Version_2.0 for more details.
Notes
The name of the executable has change from rpr2pdf.exe to skp_to_3d_pdf.exe. If you have any shortcuts pointing to the old executable, you should change them.
Upgrades
Also, there is a new 30 day free trial for the new version, so if you have already used up your trial of the previous version, you can download the new version and try it out.
See: http://www.renderplus.com/pdf/upgrades.htm Upgrades - to order upgrades.
al Hart
Register LoginAdvertisement
