    Some things I've noticed in SUP6...
    1 Posts 1 Posters 8.1k Views 1 Watching
    • thomthomT
      1. When setting the transparency to Nicer it tends to get the z-order of transparent objects wrong. The objects in the back overlaps objects in the front.
        I thought it was an issue with the graphics card on the computer I'm on. Because it's using an older IBM nVidia driver, and I can't use nVidia's drivers; they refuse to install. But when I export the scene as 2D the overlapping transparency also occur. And I was under the impression that when you export SU uses it's own software render?
        Faster or Medium setting seem to work fine however.
      2. I got the Styles tool window open.
        I select a style, export as 2D.
        Then I try to select a new style. It looks like it's displaying the styles currently in the Model, but when I click nothing happens. There's also no tooltip when I hover over the styles. I have to use the dropdown-box and select In Model again before I can interact with the styles.
