    Podium Trouble!
    extensions
    6 Posts 5 Posters 1.9k Views 5 Watching
    • N
      not registered yet
      Hi!!
      I'm a new user of Podium and needless to say I'm bowled over by its ease and convenience of use. It worked at a reasonably good speed when i rendered simple objects, but recently i tried to render my first major scene and it was terribly and unusually slow. I left it to render and after a whole 6 hours it had just reached 12%. and to top it all my scene isn't all that complex either (correct me if i'm wrong!). I've attached the model too so if anyone could please take a look at it and lemme know how its possible to achieve a faster render that would be great.
      I use the trial version and set Podium to render at 640x480 and with a lil more than medium speed with maximum smoothness. I use a laptop with 1.8Ghz, 1GB Ram and a 256mb graphics card. I just included all this info cuz i figure the problem might lie somewhere there too.
      Thanx in advance fer all the help!! God bless u guys!!
      (iamjerine)
      fORM.skp
      • I
        ilay7k
        i try to render your work with podium 1.5 b2
        and results:
        1. all your settings - test 1, render time=1m16s
          http://img522.imageshack.us/img522/4749/test1m16syo0.th.jpg
        2. only change opacity of Translucent_Glass_Safety to 19
          test 2, render time=7m18s
          http://img98.imageshack.us/img98/9971/test27m18srs8.th.jpg
        My hardware settings: amd-64bit 3200+(desktop pc), 1gb ram
        I think you need to change pc or upgrade it...or post processing in fotoshop too
        I forget to add res.1024x768
        Also try Vray for sketchup(its from biased renders...)
        • soloS
          solo
          Using your settings and at 640 x 480 I rendered it at 26 seconds.
          However I am using 1.5 b3.
          I will add some omni lighting now and see how it turns out.
          http://www.solos-art.com
          • N
            newvista
            I purchased the commercial version of podium today downloaded many types of materials like stone, wood etc from their website. I extracted the files and put them in respective sketchup material folders. (For example, if it is wood, C:\Program Files\Google\Google SketchUp 6\Materials\Wood)
            I do not see them when I open my sketchup program. I also found out that the materails I got from podium is .jpg files and the ones in sketchup material folders are .skm.
            Could somebody help me with this please? Thanks.
            • R
              remus
              You'll need to import them into SU and scale thme. From there you can then copy them into the normal materials folders.
              To do this you'll need a face which you know the size of, say 1x1m. You then go file->import and select the 'use as texture' option. If you then apply this to your surface at a size relative to the face.
              For future reference, youd probably be better of posting thigns like this in the newbie/sketchup forum.
              • N
                newvista
                Thanks remus.
