    3D Selector?
    3 Posts 2 Posters 8.4k Views 2 Watching
    • KrisidiousK
      Krisidious
      http://www.sketchucation.com/forums/scf/viewtopic.php?f=57&t=855 this got me thinking... about selection.
      I wish I had a 3D selector, one that could only select the objects within a certain area. when I'm working on houses in sketchup, I invaribly need to select things on a wall or surrounding a wall and don't want to select the things in the back ground, so I have to rotate the model into an elevation view or plan view and use the slector to slice through the plan and try to grab what I need to group. if I could select one spot in space, then a second to define the box, then pull up that selection box to the ehight I needed. then release for the capture.
      and so it was written, so shall it be done... or has it be done? well I'd like to see it none the less.
      By: Kristoff Rand
      • N
        not registered yet
        So, the selector would utilize the push/pull tool.
        nice idea!! all the components seem to already be there.
        you could use the ctrl key to toggle it on and off just like the other tools.
        (crojack)
        • KrisidiousK
          Krisidious
          I was thinking the same thing... all the tools are there... just give us a button to control it. and viola.
          By: Kristoff Rand
