    Le programme Mariocha, Format-3D : Sketch-Cuisine v26-03-20 refuse de se lancer erreur au démarrage
    sketch-cuisine
    3 Posts 2 Posters 339 Views 2 Watching
    • J
      jackfanfan
      • J
        jackfanfan
        Problème résolu, Mariocha à fait la mise à jour.
        ça fonctionne.
        • A
          Azra Salkanovic Newcomers
          Hello,
          I have recently purchased a full license for SketchCuisine via SketchUcation, and the license appears to be successfully validated (status shows "validate_success").
          However, the plugin is not functioning correctly.
          Issue description:
          The plugin appears in the Extensions menu and toolbar
          License is active and validated
          When clicking on any SketchCuisine tool (icons or menu commands), nothing happens (no dialog, no action)
          Only the info/settings window can be opened
          What I have already tried:
          Assigned the license seat correctly (1/3 seats active)
          Restarted SketchUp multiple times
          Reset workspace
          Disabled other extensions (including V-Ray and Sketch-Int)
          Completely uninstalled and reinstalled the plugin (including manual removal from Plugins folder)
          Logged in to SketchUcation and confirmed license activation
          Tested in SketchUp 2022
          Despite all of the above, the tools remain unresponsive.
          Could you please advise on how to resolve this issue, or confirm if there are known compatibility problems with current systems?
          Thank you in advance for your support.
          LG
          • Rich O BrienR Rich O Brien marked this topic as a regular topic on
