    Natural/Cinematic Camera Movement
    Scheduled Pinned Locked Moved Animator Beta
    cameraextensionssketchupanimationanimator
    6 Posts 3 Posters 821 Views 3 Watching
    • M
      melindasaur
      Hello.
      I work in Film/TV and I want to create beautiful camera flythrough animations in SketchUp and avoid having to use other software like Twinmotion or Blender.
      For example, this Blender extension allows you to record camera movement and refine it to get great results.
      Is there any way to get this kind of natural or cinematic camera movement using Animator (or another extension) in SketchUp?
      Thank you,
      Clayton
      • S
        sashapepperspray
        would this help? https://extensions.sketchup.com/extension/1c44c70e-ce3c-463c-a348-6ffb47e15bb0/clf-camera-recorder
        M 2 Replies Last reply
        • M
          melindasaur @sashapepperspray
          @sashapepperspray Thank you! I'll play with it and see what I can get.
          • M
            Hi @sashapepperspray - thank you again for sending the Chris Fullmer extension "camera recorder". However, I find that it doesn't work as needed. The main gripe I have is that the plugin always switches my camera's field of view to 30 degrees after I record, which isn't ideal as I'm trying to show off the model, and 30 degrees is very narrow. Do you know if it's possible to edit this functionality? Thank you so much.
            • S
              sashapepperspray
              I have not really used the plugin, I just now it exits, so I can't help you, sorry.
              • F
                faust07
                A largely forgotten plugin - MSPhysics.
                Also not so easy to get running under SUp2022:
                https://community.sketchucation.com/user/faust07
