    Curviloft Error
    3 Posts 3 Posters 303 Views 3 Watching
    • J
      jackieboyharpster
      I'm experiencing an error with Curviloft, I have all of the latest updates and plugins for Fredo 6 and I am using Sketchup 2025 running on Windows 11.
      The error is occurring when I try to create a mesh between two coplanar edges, I will get a message on the screen that reads, "Error in the construction of the Junctions - Try to change the parameters."
      I am able to use most of the other features for Curviloft, but creating a coplanar mesh is the one I use most to use the thru-paint plugin to show curved materials.
      I have attached an image of the error occurring in my Sketchup window.
      Any help would be very much appreciated.
      panixiaP 1 Reply Last reply
      • panixiaP
        panixia @jackieboyharpster
        @jackieboyharpster apparently, you are trying to do it with 4 curves selected using the "loft by splines" command, this is clearly user error.
        Just delete the 2 straight segments (and the attached existing face of course), then select only the 2 arcs and run the command again.
        • P
          poitiers Newcomers
          mise au point.skp
          bonjour, j'ai le même message d'erreur, mais je ne comprends pas la réponse faite au dessus merci
