    Understanding Spacers and spans ProfileBuilder 4
    5 Posts 2 Posters 115 Views 2 Watching
    • Epix3DE Offline
      Epix3D
      SpanComponents.skp Trying to understand spacers in ProfileBuilder 4.
      Why are the measures wrong ? What am I missing?
        Did you try toggling off the Place Component at End? For both 'stacks'
        Epix3DE 1 Reply Last reply Reply Quote 0
        • Epix3DE Offline
          Epix3D @Rich O Brien
          @Rich-O-Brien
          Thank you for your suggestion , -but it did not help..
          SpanComponents.skp
          Find the file attached
            I presume you want a block placed at 1219mm intervals with no overlaps. Along with the top row getting offset by half?
            If so uncheck Max and uncheck At End on both component rows. That stops blocks overlapping .
            Epix3DE 1 Reply Last reply 😊 Reply Quote 0
            • Epix3DE Offline
              @Rich-O-Brien
              Thank you Brian. Second course was offset. Had to remove and reset start setback (half stone)for it + Layout from start to change ; )
              Again, -thank you for sorting out.
