    [Plugin] Selective Attribute Modification in Dynamic Components
    5 Posts 2 Posters 395 Views 2 Watching
      josebadc
      This extension allows you to change any of the attributes* individually while keeping the rest unchanged.
      jd_selective_dc_editor2.3.rbz
      In SketchUp, when you change an attribute of two dynamic components, the rest of the attributes also change. This extension allows you to change any of the attributes* individually while keeping the rest unchanged.
      *Attributes shared by both components.
      Video:
      1 Reply Last reply πŸ‘ Reply Quote 1
        Very clever. If you want to add it to our ExtensionStore let me know.
          josebadc
          Yes, of course, thank you
            You need to logout of your account.
            Then login at sketchucation.com homepage
            You should see a Dev Tools buttons in the header
            Dev Tools for Sketchucation Tools
            In there is a portal to list your extension/s on our site and in the Sketchucation Tools extension.
            New extensions require approval before going live. Feel free to poke around.
              josebadc
              jd_selective_dc_editor_v3.0.rbz
              What's New β€” v3.0
              -All attributes in a single table: all editable TEXTBOX/LIST attributes found across the selection are displayed at once, eliminating one-at-a-time popups.
              -Smart multi-selection: attributes are shown even when only some selected components contain them, with a counter such as 3/5. Applying changes only affects components that actually contain that attribute.
              -Full group and nested component support: select a group, wrapper component, or nested element and the plugin recursively finds Dynamic Components at any depth.
              -Independent instances: improved component instance handling prevents changes to one instance from unintentionally affecting other copies.
              -Live auto-refresh: the editor remains open and automatically updates whenever the model selection changes, with no need to close and reopen it.
              -Improved Apply & Undo: Dynamic Component updates are handled more reliably within a single SketchUp Undo operation.
              -Extended timeout for complex operations: the Dynamic Components operation timeout has been increased to 30 seconds.
              -Improved performance: definition-level caching avoids repeatedly scanning identical sub-assemblies, attribute filtering uses a precompiled regular expression, and live refresh uses debouncing to prevent unnecessary rebuilds during rapid selection changes.
              -Better error handling: errors now display a message to the user and print the full backtrace to the Ruby console instead of failing silently.
              -Cleaner interface: only the user-facing attribute name is displayed; internal formula/attribute names are hidden.
