    Help with ProfileBuilder4 Wallblocks
    9 Posts 2 Posters 899 Views 2 Watching
    • Epix3DE
      Epix3D
      Trying to make an automatic assembly of wallblocks but long time since I Used it so I need help.
      How can I make this functional?
      πŸ”½ BlockWall.skp
        ProfileBuilder can build an Assembly from a selection.
        Model parts needs to be accurate though. If things have skewed axis location you'll end up with a mess.
        • Epix3DE
          Epix3D
          I have a problem making the blocks without intersecting eachother when drawing. Tryng to maximize with whole blocks only, -that is -no overlapping geometry.
          Block1.skp
            Did you uncheck Max ?
            • Epix3DE
              Epix3D
              Thank you Rich.That was it ; ) Works fine in straight lines but how can I make a curved wall with blocks facing forward paralell to the cuve?
              Block1.skp
              This Curved wall was done manually
              CuvedWall.skp
                The component axis sets the insertion point location. Try setting the brick component axis to be the center so all rotation originates from that location.
                That would mean using the Left/Right offset value to get what you need.
                • Epix3DE
                  Epix3D
                  Wow Rich! Thank you. Will try it out
                    You may need to set Smooth too
                    • Epix3DE
                      Epix3D
                      Thank you ;: )
