    SketchVault
    6 Posts 2 Posters 866 Views 2 Watching
    • majidM
      majid
      I have been developing a vault generator add-on for Blender 3D that is aimed to mimic RhinoVault (considering Blender cons/pros vs Rhino).
      It tries to find the best compression-only form for the given input mesh. Recently, I used Gemini to translate it to work with SketchUp. It is in its early stages and would be fine if anyone helps me to improve it.
      # SKETCHUP FOLDING VAULTS V4 (Robust Non-Flat Mesh + Red Anchors) | By Majid Yeganegi AI optimization -2025 Nov.
      require 'sketchup.rb'
      module VaultPlugin
        # --- 1. Math Helper Classes (Unchanged for performance) ---
        class SparseMatrix
          attr_reader :n_rows
          def initialize(n_rows)
            @n_rows = n_rows
            @rows = Hash.new { |h, k| h[k] = {} }
          def add(r, c, val)
            return if r >= @n_rows || c >= @n_rows
            @rows[r][c] ||= 0.0
            @rows[r][c] += val
          def dot(vec)
            result = Array.new(@n_rows, 0.0)
            @rows.each do |r_idx, col_data|
              sum = 0.0
              col_data.each { |c_idx, val| sum += val * vec[c_idx] }
              result[r_idx] = sum
            result
        class VectorMath
          def self.sub(a, b); a.zip(b).map { |x, y| x - y }; end
          def self.add(a, b); a.zip(b).map { |x, y| x + y }; end
          def self.scale(vec, s); vec.map { |x| x * s }; end
          def self.dot(a, b); a.each_with_index.reduce(0) { |sum, (val, i)| sum + val * b[i] }; end
        # --- 2. CG Solver ---
        def self.cg_solve(matrix, b, x0, max_iter, tol)
          x = x0.dup
          r = VectorMath.sub(b, matrix.dot(x))
          p = r.dup
          rsold = VectorMath.dot(r, r)
          max_iter.times do
            ap = matrix.dot(p)
            p_ap = VectorMath.dot(p, ap)
            break if p_ap.abs < 1e-15
            alpha = rsold / p_ap
            x = VectorMath.add(x, VectorMath.scale(p, alpha))
            r = VectorMath.sub(r, VectorMath.scale(ap, alpha))
            rsnew = VectorMath.dot(r, r)
            break if Math.sqrt(rsnew) < tol
            p = VectorMath.add(r, VectorMath.scale(p, rsnew / rsold))
            rsold = rsnew
          return x
        # --- 3. Helper: Check if Material is RED ---
        def self.is_red?(entity)
          return false unless entity.material
          c = entity.material.color
          # Check for Pure Red (255, 0, 0) or close to it
          return true if c.red > 200 && c.green < 50 && c.blue < 50
          return false
        # --- 4. Main Process ---
        def self.process_mesh(selection_mesh, density_input, load_input, scale_factor, iterations)
          model = Sketchup.active_model
          entities = model.active_entities
          # A. Topology Extraction
          verts = []
          v_to_id = {}
          faces = selection_mesh.grep(Sketchup::Face)
          if faces.empty?
            UI.messagebox("Please select a Mesh (Faces) first.")
            return
          faces.each do |f|
            f.vertices.each do |v|
              unless v_to_id.key?(v.entityID)
                v_to_id[v.entityID] = verts.length
                verts << v
          n = verts.length
          # B. Explicit Anchor Detection (THE "RED" RULE ONLY)
          anchors = []
          # Check 1: Red Faces
          faces.each { |f| anchors.concat(f.vertices.map { |v| v_to_id[v.entityID] }) if is_red?(f) }
          # Check 2: Red Edges
          edges = faces.map { |f| f.edges }.flatten.uniq
          edges.each do |e|
            if is_red?(e)
              anchors << v_to_id[e.start.entityID]
              anchors << v_to_id[e.end.entityID]
          anchors = anchors.uniq
          if anchors.empty?
            UI.messagebox("Error: No RED anchors found! The mesh will float freely.\nPlease paint at least one edge or face RED.")
            return
          # C. Index Mapping
          free_map = []
          global_to_free = {}
          free_count = 0
          (0...n).each do |i|
            unless anchors.include?(i)
              free_map << i
              global_to_free[i] = free_count
              free_count += 1
          n_free = free_map.length
          if n_free == 0
            UI.messagebox("Error: All selected vertices are anchors. Nothing to calculate.")
            return
          # D. Build Edges Index
          edges_idx = edges.map do |e|
            id1 = v_to_id[e.start.entityID]
            id2 = v_to_id[e.end.entityID]
            [id1, id2] if id1 && id2
          end.compact
          # E. TNA Setup & Matrix Assembly
          q_val = density_input
          l_ff = SparseMatrix.new(n_free)
          d = Array.new(n, 0.0)
          # Build Laplacian (L_ff) and Diagonal (d)
          edges_idx.each do |u, v|
            w = q_val
            d[u] += w
            d[v] += w
            u_free = !anchors.include?(u)
            v_free = !anchors.include?(v)
            if u_free && v_free
              uf, vf = global_to_free[u], global_to_free[v]
              l_ff.add(uf, vf, -w)
              l_ff.add(vf, uf, -w)
          free_map.each { |i_glob| l_ff.add(global_to_free[i_glob], global_to_free[i_glob], d[i_glob]) }
          # F. Vertical Equilibrium (Solve for Final Z: Z_f)
          # Initial Z-positions of free nodes (used as the initial guess and for calculating Delta Z later)
          z_orig_free = Array.new(n_free)
          free_map.each_with_index { |glob_idx, i| z_orig_free[i] = verts[glob_idx].position.z }
          z_current = z_orig_free.dup
          # Iterative Solve for Z_f
          iterations.times do
            rhs = Array.new(n_free, -load_input) # -Pf
              w = q_val
              # Contribution of fixed anchors to the RHS (-Lfa * Za)
              if u_free && !v_free
                rhs[global_to_free[u]] += w * verts[v].position.z
              elsif !u_free && v_free
                rhs[global_to_free[v]] += w * verts[u].position.z
            z_current = cg_solve(l_ff, rhs, z_current, 200, 1e-5)
          # G. Calculate and Apply Displacement (Delta Z)
          # Delta Z = Z_final - Z_original. This is the displacement vector.
          # It will be negative for a hanging form (since Z_f < Z_orig_f).
          delta_z = VectorMath.sub(z_current, z_orig_free)
          model.start_operation("Generate Vault", true)
          group = entities.add_group
          mesh_out = Geom::PolygonMesh.new
          final_pts = []
          # Use the sign of the scale factor to determine the flip
          # scale_factor = -5.0 means: flip the negative displacement (to positive) and scale by 5.0
          scale = scale_factor
          (0...n).each do |i|
            v_orig = verts[i].position
            if anchors.include?(i)
              final_pts << v_orig # Anchors stay at their original Z
            else
              dz_calc = delta_z[global_to_free[i]]
              # Z_final = Z_original + (Delta Z * Scale)
              # If Delta Z is negative (hanging form) and Scale is negative (-5.0),
              # the result is positive displacement, creating the arch/vault.
              z_final = v_orig.z + (dz_calc * scale)
              final_pts << [v_orig.x, v_orig.y, z_final]
          # Reconstruct faces
          faces.each do |f|
            idxs = f.vertices.map { |v| v_to_id[v.entityID] }
            mesh_out.add_polygon(idxs.map { |k| final_pts[k] })
          group.entities.add_faces_from_mesh(mesh_out)
          group.name = "Vault_Result"
          group.material = "White"
          group.entities.grep(Sketchup::Edge).each { |e| e.soft = true; e.smooth = true }
          model.commit_operation
        # --- 5. UI Dialog ---
        def self.show_dialog
          prompts = ["Force Density (Stiffness)", "Load", "Height Scale (Multiplier)", "Iterations"]
          # Default Scale set to 5.0, as requested.
          defaults = [1.0, 1.0, 5.0, 30]
          input = UI.inputbox(prompts, defaults, "TNA Settings")
          return unless input
          sel = Sketchup.active_model.selection
          self.process_mesh(sel, input[0], input[1], input[2], input[3])
        unless file_loaded?(__FILE__)
          menu = UI.menu('Plugins')
          menu.add_item('Create Vault (TNA)') { self.show_dialog }
          file_loaded(__FILE__)
      • TIGT
        Majid
        I'll look at it for you and send a fixed version by PM - it might be early next week...
        • majidM
          majid
          I appreciate it.
          • majidM
            majid
            Using Gemini, the code is now better, though it generates numerous materials. To make it work: Select the "anchors (face/edge) color it in pure red. Select desired mesh, run the plugin
            Here is the file
            Majid_FoldingVaults.rbz
            • TIGT
              Thanks for the update.
              You saved me from doing the work !
              Seems to work as it should with undo and so on.
              Much better structured code-set.
              The code # rem's are much more helpful.
              It needs more guidance about the settings and what they do.
              Also on how the 'red' mesh areas control the results.
              Is the new mesh meant to be colored without any choice ?
              It's neat, but perhaps not always wanted ?
              You could add a simple checkbox option to the dialog - 'Color by Z height'
              then skip that coloring part around line#279=#291 if it's set 'off'...
              • majidM
                majid
                Thanks TIG, I am honored that my hero is commenting on the path I am going.
                Okay I will add more guidance on each section.
                Also will try to make it "dynamic" before finalizing.
                Color coding is meant to show the pressure forces on each part of the mesh.
                It meant to generate the best "compressure-only" structure out of the given input.
                will update it soon.
