    Photoreal setting in Sketchup 2026.
    3 Posts 2 Posters 1.4k Views 2 Watching
      OK, enable them to see what was what. Tried to change back to the standard shaded textures and sky etc but not happeneing. When this happens the only way to correct the situation is to select the classic engine in graphics prefs and reboot. Then you can select the shaded textures without the photoreal background and the new graphics engine.
        When you select Photo Real Textures an environment is added. Go into the Environments panel, go to the In Model envronments, select No Environment, and then purge from the Details menu. No need to select the Classic Graphics Engine.
          Thanks Dave, I tried searching on the Sketchup support site but apparently I do not have a right to see the results.
