    Measurement window location in 2025
    4 Posts 2 Posters 987 Views 2 Watching
      joshvt
      I recently updated to 2025. The measurement window is now in the bottom left corner instead of the bottom right. Is there a way to make it go to the bottom right where it used to exist?
        It should have been in the lower right corner by default. Presuming you are using SketchUp on Windows, go into View>Toolbars and deselect Measurements.
          joshvt
          Yes, windows. for some reason was having trouble floating/ undocking it. figured that out and put it where I want it. Thanks for responding.
            Dave R @joshvt
            @joshvt said in Measurement window location in 2025:
            If you untick the box for Measurements in the View>Toolbars panel the window should be displayed in the default lower right corner location.
