    Shortcut command does not work with multiple selected texts.
    2 Posts 2 Posters 321 Views 2 Watching
    • K
      koliboti
      If I put the command: Text Position on a shortcut. Then the shortcut only works for one selected text (dimension). If I select multiple texts (dimensions), the shortcut command does not work. If I change the Text Position of the text (dimension) in Entity Info, it works fine there. Only the shortcut does not work with multiple selected texts (dimensions).
        The Text Position command also shows in the Context menu for a single selected dimension, too.
        There's no need for a keyboard shortcut if you're going to change the text position in Entity Info, anyway.
