    fredo6 licences
    31 Posts 4 Posters 1.9k Views 4 Watching
    • F Offline
      fjsgruppe
      I finally messed everything up.
      My workstation is connected to our intranet.
      My sketchup files are stored on a NAS.
      Our network-specialist opened a new user account and connected it to the intranet.
      He used a special program to migrate SU pro 2024 to the new user and SU seemed to be working.
      Later we deleted the old username.
      A time later malfunction started and increased.
      I tried some repair installations solved some problems, but couldn’t get it to work properly.
      Using templates became impossible, SU was unable to connect to the template path.
      Today I deleted SU pro 2024 and tried a complete new setup (SU deleted and admin setup). The setup stopped because of not existing files.
      (See the picture), must be the templates file on the no longer existing path. How the hell does SU know about that?
      My classic version of SU pro 2021 still works but - as we forgot to migrate it to the new User before - there is the same trouble with the path to the template folder.
      re
      fjs
      Don't worry, be happy!
        The file: C:\Users\YOURNAME\AppData\Local\SketchUp\SketchUp 20nn\SketchUp\PrivatePreferences.json
        Contains the fixed path to your Templates folder, under:
        "File Locations": {
        "Templates": "C:\\Users\\YOURNAME\\AppData\\Roaming\\SketchUp\\SketchUp 20nn\\SketchUp\\Templates\\",
        Note you need to use the correct user-name and SketchUp version in lieu of 20nn.
        If you edit that with the right name while SketchUp is closed does that improve things ??
        Changing a user-name does not change the underlying original user-name, and if that's happened it could confuse SketchUp when it's setting these fixed paths...
        If that's not fixed SketchUp might still try to reset this preferences file to what it thinks is the correct path !
        • F Offline
          fjsgruppe
          I was changed the json files, the path to the templates is now correct in both SU 2021 & 2024.
          There are no more errors reported. Thank you very much!
          Still - SU 2024 does not work.
          Registration ends in asking to ‘restart the browser’ and stops - although I am activ registated.
          That seems to be a registraiton thing. I'll ask the seller.
          Tig: I really appreciate your help
          Schöne Grüße aus Deutschland
          fjs
          • F Offline
            fjsgruppe
            I changed ...
              So we have a solution??
              The remaining v2024 issue seems different ?
              I am not familiar with errors and messages in German...
              Perhaps a full re-installation of v2024 would help ?
              With the subsequent json file 'fix' ??
              • F Offline
                fjsgruppe
                Hi TIG,
                that json file - the first I ever opened - is really very interesting!
                How did you find out about it????? Amazing!
                I changed the path name of the templates-file and restored the json file.
                That way the job was done.
                No more (no file finding-) errors in SU pro 2021 and 2024!
                I tried a full re-installation after restoring the json file.
                But SU 2024 is still not willing to endup the setup procedure.
                It always stops and asks me to restart my browser.
                Braking up the process doesn’t show the (no file finding-) error message anymore!
                Concerning the installation process I asked SU-support and the German reseller for help.
                Schöne Grüße
                fjs
                • F Offline
                  fjsgruppe
                  Re-installation log file found:
                  SU tries to re-install from a not existig user 'FJSCH~1'
                  Of course that can't work!
                    I suspect the unexpected user name ending ~1 is because your umlaut containing name is there under the surface.
                    Renaming it FJS doesn't change it's underlying name ?
                    Can your tech guy help sort out your user-account name, without any accented characters etc [as prohibited by Microsoft, but Windows lets them slip through]
                    Have you tried downloading the installer exe again from SketchUp or your local supplier ?
                    There are two versions one is a larger file containing everything needed, the other downloads some components from the web...
                    The larger one is the safer option...
                    Depending where it fails there might still be a MSI file extracted with all of the needed files, even if the full installation stalled.
                    If you find that you can try running it...
                    e.g. C:\Users\YOURUSERNAME\AppDataLocal\Downloaded Installations\SketchUp 2024\SketchUp\SketchUp 2024.msi
                    Try the FJS and perhaps the FJSCHS~1 user-name...
                    • F Offline
                      fjsgruppe
                      Problem solved:
                      There were still a nuber of json files with an incorrect path. In addition, these paths were also entered incorrectly in the registry in some places.
                      • F Offline
                        fjsgruppe
                        nuber = number
                        • F Offline
                          fjsgruppe
                          Thank you for your hepl!!1
                          • 2 / 2
