    Cut through roof
    5 Posts 2 Posters 322 Views 2 Watching
      danna
      What is the best / easiest way to cut the roof off at the vertical plane I put in,
      want to keep the front part.
      Is there a plugin that would do this ? ( SU ver 8 )
        No need for a plugin. Just select all of the geometry, right click on it, choose Intersect Faces>With Selection and then erase the part you want to keep.
        D 1 Reply Last reply Reply Quote 1
          danna @Dave R
          @Dave-R said in Cut through roof:
          Roof is group ... vertical face is group.
          Can I select all as is ... or should I explode then first ?
            Explode the vertical face, use Edit>Cut to cut it to the clipboard, open the roof group for editing, hit Edit>Paste in place. Then select all, use Intersect Faces>With Selection and erase the unwanted stuff.
            D 1 Reply Last reply Reply Quote 0
              danna @Dave R
              Thank you !
