    Bug report/change suggestion - ESC key forces Sketchup to perform UNDO
    4 Posts 2 Posters 294 Views 2 Watching
    • K Offline
      kaleen_pl
      Re: [Plugin][$] ThruPaint - v2.8a - 09 Nov 24
      Dears, this is Licensed ThruPaint 2.8, MacOS, Sketchup 2021. We got many unexpected Sketchup behaviour at our company until we realized that it has to do with ThruPaint causing some unexpected Undo(Cmd+Z). When we open Thrupaint and try pressing ESC to abort/close it will actually force UNDO operation from Sketchup, which normally is Cmd+Z. This is very counter intuitive. ESC key does not perform UNDO in Sketchup but is usually used to escape tools. This is why I believe it is kind of a bug. I know we can use scpace bar or X to close ThruPainty window but it is still causing mess in our projects regularly.
      Movie is uploaded below where I demonstrate it,
      -I am using Move tool to Move a cabinet,
      -then opening ThruPaint,
      -then pressing ESC in 0:15sec,
      -the cabinet is then reversing to previous position.
      If I would have kept pressing ESC key Sketchup would have continued to UNDO other past actions until UNDO history runs out.
      Sorry for low res, was trying to keep the size down.
      ThruPaint2.8a.mov
      fredo6F 1 Reply Last reply Reply Quote 1
      • fredo6F Offline
        fredo6 @kaleen_pl
        @kaleen_pl
        I can make Escape not do an Undo, while letting Ctrl-Z do an undo.
        • fredo6F Offline
          fredo6
          Fixed in ThruPaint v2.8b, just published.
          K 1 Reply Last reply Reply Quote 1
          • K Offline
            kaleen_pl @fredo6
            @fredo6 said in Bug report/change suggestion - ESC key forces Sketchup to perform UNDO:
            Thanks, have not tested is yet but your prompt response is awesome!
