    2024 CTRL COPY NOT WORKING
    5 Posts 2 Posters 570 Views 2 Watching
    • boofredlayB Offline
      boofredlay
      I have recently run into a problem. Using ctrl while moving or using the push pull tool does not make a copy anymore. I have no idea what changed. I have tried using a different keyboard with no luck either.
      I have run as administrator and done a repair twice, no luck.
      I uninstalled, run administrator and reinstalled, no luck.
      I am completely stuck. No idea what to try next.
      Thanks for any insight.
        boofredlay
        I installed sketchup 2017 make and all works fine. So there is something gone wrong with 2024 all of the sudden.
        TIGT 1 Reply Last reply Reply Quote 0
          TIG Moderator @boofredlay
          @boofredlay
          The modifier key [Ctrl etc] has changed...
          Press and hold [with release to revert]
          versus
          Press and release [with press again to revert]
            boofredlay
            Yes I realize it changed. I have been using 2024 since it's release. This behavior just seems to have happened min session. It was working fine then not.
            I should add that I restarted my computer each time I repaired or reinstalled with no luck.
              boofredlay
              Hmm, curious but happy.
              I restarted yet again and it seems to have fixed it.
              Here is hoping.
