    WrapR compatibility with sketchup 2024
    4 Posts 3 Posters 306 Views 3 Watching
    • F Offline
      francisquitof
      This is a tool I use quite often to make my UV unwrap but it’s not compatible with sketchup 2024 and on the website there’s no new version to upgrade, I’ve sent a couple mails but had no answer, does anyone know if the developer/s will keep developing it?
      G Rich O BrienR 2 Replies Last reply Reply Quote 0
      • G Offline
        Gábor @francisquitof
        Hi @francisquitof ,
        The Wrap-R email forwarding stopped working and I haven't noticed it. Now I see there are a few unforwarded/unanswered emails and I am processing them now. Sorry for the delay.
        Wrap-R 2024 will be out next week.
          Rich O Brien Moderator @francisquitof
          @francisquitof said in WrapR compatibility with sketchup 2024:
          A workaround is to use @alsomar wonderful OldSave extension to save your model as a copy using the less restrictive skp file format
          Launch WrapR as a standalone app and Open... the model in WrapR. UV unwrap and save then import that model into SketchUp.
          Not the ideal workflow but it works
          • G Offline
            Gábor
            Wrap-R 2024.0 has been published. You can download the .exe from: https://wrapr-download.s3.amazonaws.com/WrapR-installer_2024_0.exe
