    You must install Libfredo6...
    2 Posts 2 Posters 197 Views 2 Watching
    • V
      vottak
      Re: [Plugin Library] LibFredo6 - v14.5f - 07 Aug 24
      The latest version of the plugin 14.5F, Sketchup version 24.0.553 was installed
      When starting, I see the message:! [Alt Text] (https://i.imgur.com/9sszlayq.png)
      What is the problem?
      Thank you
      TIGT 1 Reply Last reply
      • TIGT
        TIG Moderator @vottak
        @vottak
        Your image link doesn't work.
        You can add an image to your post by simply using drag-n-drop...
        If the message is telling you you need a newer version of Libfredo6: have you installed it and restarted SketchUp to sync everything ?
        Do you have the latest versions of the desired Fredo extensions installed ?
        Do you have the latest version of the SketchUcation toolset installed ? [for the licensing]
        After these installations you need to restart SketchUp so everything is synced.
        Also you need to license Fredo's extensions after any trial period - their submenu under 'Tools' covers activation and management...
