    LibFredo6 glitch ... can't install Roundcorner
    2 Posts 2 Posters 223 Views 2 Watching
      Tula Woodworking
      First off, greetings! This is my first post. Here's my dilemma:
      1. I installed LibFredo6 to install and run RoundCorner.
      2. Despite this, I am continually prompted to install the LibFredo extension every time I open a SketchUp file on my desktop.
      3. The Roundover extension will not install despite LibFredo being installed
      I'm on a tight deadline to complete designs, and I'm pretty amazed at the extent of glitches. Any help would be appreciated!
      TIGT 1 Reply Last reply Reply Quote 0
        TIG Moderator @Tula Woodworking
        @Tula-Woodworking
        Have you restarted SketchUp to sync everything ?
        Have you installed the SketchUcation Tools needed for licensing ?
        Assuming you are using Windows - have you installed Sketchup properly ?
        Double-clicking the installer's exe file to 'Run' it is not enough, even if your user account has admin powers - doing so can cause unpredictable issues, often around permissions and file access.
        It can be repaired without needing to re-install SketchUp - do the following...
        It will leave any installed files etc unaffected...
        Close SketchUp.
        Find its installer exe file - usually in your Downloads folder [down load a new copy if you no longer have it].
        Select the exe file's icon, right-click > context-menu > Run as administrator
        When prompted choose Repair.
        When it finishes restart SketchUp.
        Any improvement ?
