    HELP! Dimensions Not Displaying
    3 Posts 2 Posters 537 Views 2 Watching
    • K Offline
      kylekin Newcomers
      All my dimensions have disappeared. Even using the dimension tool they will simply not display. I can't even use D. Bur's Dimension tools. Dimensions work on all my other files. Even when I toggle dimensions on and off the file (using Tigs dimension plug in) they will not display. I've tried everything. "Dide too small" is not checked in model info. Any ideas? It's a large, complicated file with many scenes and I simply can't cut and paste the model into an empty scene because I would be losing days of work.
        Dave R @kylekin
        @kylekin what version of SketchUp are you using? Share the SketchUp file so we can see what you are working with.
        K 1 Reply Last reply Reply Quote 0
        • K Offline
          kylekin Newcomers @Dave R
          @Dave-R Using SU 2024 updated. It's a file with many scenes. Very strange but some of the scenes will display the dimensions and others will not. Even when I change the style of the scene to match another scene where it works, that scene will still not display the dimensions. I would link to the file but it is a proprietary thing that I can't post. I have a workaround now if I need to get dimensions but wondering if you can shed any insight into why this would be happening.
