    import roads
    1 Posts 1 Posters 256 Views 1 Watching
    • M
      miikka1978
      What would be the best way to crate a shell/single surface out of this Cat Mask 3D model?
      I would like to create a surface of the "front side" of this model and then create a defined thickness for the model, with Shell type of Plugin, see link to image below. The reason for this is that I plan to 3D print this and therefore I would like to have certain thickness.
      My plan was to use a Front view and Prallell Projection Gamera and select only visible faces but this still select also the faces in the back.
      Do you have any good ideas/means for selecting only "Front side of the model" in complex geometry like this?
      https://ibb.co/qs8jmZZ
      • Rich O BrienR Rich O Brien marked this topic as a question on
      • Rich O BrienR Rich O Brien marked this topic as a regular topic on
