[Plugin] Fredo Layport - v1.4a - 19 Dec 25
The information on Fredo Layport is maintained on the Plugin Home Page of Fredo Layport. This is also where you can download the RBZ file.
IMPORTANT: Fredo Layport is available for SU2023 and above.
- LibFredo6: v15.6a or above
- Sketchup version: SU2023 and above
- Platform: Windows and Mac OSX
- Usage: free
Fredo Layport helps to visualize in Sketchup the rectangle area (Layport) which will be displayed in a Layout document for a Scene based on its current camera.
The main features are:
- Create and manage Layports of any size and assign them to scenes. The Layport dimensions can be extracted from existing Layout documents.
- Center Objects at any nested level within a Layport, with margins and optional auto-centering.
- Assign paper scale to 2D Scenes , so that they can be printed at scale
- QuickPrint function to generate a PDF for printing a selection of scenes, with a basic presentation, and the respect of paper scale, if defined. You can also generate explicitly a Layout document and / or a PDF document.
The help is integrated in the extension, as a Quick Card.
Here is the Quick Card as a PDF
Overview and main features
Print at Scale
Please, if it is possible, to make the Layport names longer (with much more characters).!
Thank you.! -
NEW RELEASE: Layport v1.2a - 31 Dec 24
Requirements:
- LibFredo6 14.5
Layport v1.2a is a maintenance release:
- Extension of validity
Home Page of Layport for information and Download.
Ello,
It seems that the version number is not changed in the code, it always displays 12a. -
Thanks.
Actually the version is v1.2a (not v1.3a). -
NEW RELEASE: Layport v1.3a - 01 Jun 25
Requirements:
- LibFredo6 14.5
Layport v1.3a is a maintenance release:
Fredo, can you support earlier versions, I have SU 2021 Professional which from the surface doesn't look too much different from SU2023. I'm sure there are some SU code changes.
Thanks,
Wayne -
Layport is based on Overlay, which are only available for SU2023 and higher versions.
NEW RELEASE: Layport v1.4a - 19 Dec 25
Requirements:
- LibFredo6 15.6
Layport v1.4a is a maintenance release:
Register LoginAdvertisement
