    [Plugin] Fredo Layport - v1.4a - 19 Dec 25
    9 Posts 4 Posters 779 Views 4 Watching
    • fredo6F Offline
      The information on Fredo Layport is maintained on the Plugin Home Page of Fredo Layport. This is also where you can download the RBZ file.
      IMPORTANT: Fredo Layport is available for SU2023 and above.
      • LibFredo6: v15.6a or above
      • Sketchup version: SU2023 and above
      • Usage: free
      Fredo Layport helps to visualize in Sketchup the rectangle area (Layport) which will be displayed in a Layout document for a Scene based on its current camera.
      The main features are:
      • Create and manage Layports of any size and assign them to scenes. The Layport dimensions can be extracted from existing Layout documents.
      • Center Objects at any nested level within a Layport, with margins and optional auto-centering.
      • Assign paper scale to 2D Scenes , so that they can be printed at scale
      • QuickPrint function to generate a PDF for printing a selection of scenes, with a basic presentation, and the respect of paper scale, if defined. You can also generate explicitly a Layout document and / or a PDF document.
      The help is integrated in the extension, as a Quick Card.
      Here is the Quick Card as a PDF
      Overview and main features
      Print at Scale
      • F Offline
        FlorinAp
        Please, if it is possible, to make the Layport names longer (with much more characters).!
        Thank you.!
        • fredo6F Offline
          NEW RELEASE: Layport v1.2a - 31 Dec 24
          Requirements:
          • LibFredo6 14.5
          Layport v1.2a is a maintenance release:
          • Extension of validity
          Home Page of Layport for information and Download.
          Main post of this Layport thread.
          • F Offline
            FlawinneF
            Ello,
            It seems that the version number is not changed in the code, it always displays 12a.
            • fredo6F Offline
              Thanks.
              Actually the version is v1.2a (not v1.3a).
              • fredo6F Offline
                NEW RELEASE: Layport v1.3a - 01 Jun 25
                Requirements:
                • LibFredo6 14.5
                Layport v1.3a is a maintenance release:
                • W Offline
                  waynehughes2
                  Fredo, can you support earlier versions, I have SU 2021 Professional which from the surface doesn't look too much different from SU2023. I'm sure there are some SU code changes.
                  Thanks,
                  Wayne
                  • fredo6F Offline
                    Layport is based on Overlay, which are only available for SU2023 and higher versions.
                    • fredo6F Offline
                      NEW RELEASE: Layport v1.4a - 19 Dec 25
                      Requirements:
                      • LibFredo6 15.6
                      Layport v1.4a is a maintenance release:
