    Trouble with Fredo scale and push pull
    2 Posts 2 Posters 154 Views 2 Watching
    • B
      bsemonsen
      Problems with Fredo scale and Fredo push/pull. Since updating to sketch 2024 these extensions don't work. They show up in both the sketchup extensions manager and the sketchucation extensions manager. They do not show in the VIEW-Tool Palettes so I cannot make them visible. I have uninstalled and reinstalled.
      They are the latest versions. They work fine in v2023.
      Any ideas?
      TIGT 1 Reply Last reply
      • TIGT
        TIG Moderator @bsemonsen
        @bsemonsen
        You say they "are the latest versions", but most of Fredo's extensions have recently been updated to suit v2024.
        Also you will need the latest LibFredo AND the SketchUcation toolset [for the licensing etc].
        Download them/install from SketchUcation.com
        If you have installed all of these extensions AND restarted SketchUp, but you still have issue report back...
        Also, when you installed v2024 did you do it properly ?
        You can 'repair' a faulty installation as follows...
        Close SketchUp.
        Find the v2024 installer's exe file - usually in you Downloads folder.
        Select its icon, right-click > context-menu > "Run as administrator"
        When prompted choose "Repair"
        When it completes launch SketchUp and see if there's any improvements...
        Installing any complex Windows app by double-clicking its installer's icon to "Run" it gives a different result - even if you user-account has admin-powers.
        This way can cause unexpected and unpredictable issues - especially around file/folder/preferences being read or saved...
        Doing a "Repair" will do no harm, and leave anything you've already set up unaffected.
