    photoMatch and watermark
    4 Posts 2 Posters 330 Views 2 Watching
      luisto
      photoMatch and watermark, use simultaneously, you can
      • Rich O BrienR Online
        Rich O Brien Moderator @luisto
        @luisto said in photoMatch and watermark:
        Can you rephrase that?
          luisto
          in the same scene I can load a watermark and then match photos with the same image on it. So when you change the orbit even slightly, the image does not disappear. Is there any contraindication to this?
            @luisto Photomatch image is linked to camera position. If you orbit then the position changes so the match image will disappear.
            If you want an image to be persistent it would need to be a style with a background image
