    Double lines in design when exporting for lazer cutter
    4 Posts 3 Posters 387 Views 3 Watching
    • E
      ericbruggema
      Hi there,
      Ive created a couple of designs with i want to send to the lazer cutter. Now i've exported it to PDF/DWG/DXF and tried to load then into LightBurn (1.5.02, latest version)
      alt text
      alt text
      and now scaled, you see double lines...
      How to solve this?
      alt text
      I don't want double lines on lots of lines in the drawing... where did i go wrong?
        If you import the exported dwg back into SketchUp do you see double lines?
        If NO it could be the importer in your app that's the cause. If YES, then there maybe something in the source SKP file.
        Once you include a secondary app into the mix the likely cause would be harder to detect. Can you reproduce on just a small sample of geometry?
        E 1 Reply Last reply
        • E
          ericbruggema @Rich O Brien
          @Rich-O-Brien Thanks for you usefull answer, i've loaded a dxf into Sketchup again and there where no extra lines...
          I'll look into it further!
          • BoxB
            I see you are using Eneroth's Laser Tools. Why not add Eneroth's SVG Exporter to get them into Lightburn.
