    [OUTDATED] Rayscaper 0.8.4 Alpha
    2 Posts 1 Posters 251 Views 1 Watching
    • pixelcruncherP
      Hey folks,
      You can get the test build for Rayscaper, Windows, version 0.8.4 Alpha here.
      Remember this is alpha software. Have a look here to see what that means.
      Changes since the last build:
      • Fix a GPU rendering bug. The same scene, with the same configuration, would sometimes give different results when
        re-rendering the scene using the GPU.
      • Support material inheritance. SketchUp faces that don't have geometry assigned can inherit the material from their
        parent instance or group.
      • Fix the roughness control for glass and metal materials. Low roughness values look more reasonable now.
      • Remove the spherical texture mapping option.
      Quick Tips
      • If this is your first time installing Rayscaper, have a look at our installation instructions.
      • If you installed Rayscaper before, have a look at our upgrade guide.
      • We also have a quick start guide with a free demo scene.
      • The documentation is here. Documentation is a work in progress.
      Reach Out
      When you get stuck, have questions, give some feedback or just want to say hi. Don't hesitate to create a post in this forum (Extensions & Applications Discussions) or send me a private message. We have a documentation section on finding help.
      Happy Rendering!
      Thomas
      • pixelcruncherP
        Version 0.8.5 is out now: https://sketchucation.com/forums/viewtopic.php?f=80&t=76689
