    Volume M3
    6 Posts 2 Posters 268 Views 2 Watching
      mxkpost Newcomers
      Can anyone explain how to get a cubic meterage for my model of a concrete foundation.
      Volume does not display in the entity box other square meter.
      I have used Solid Inspector and all is well.
      Any thoughts anyone?
      • BoxB Offline
        You must make the geometry a group or component for it to read volume. If you are seeing area you must be selecting faces.
          mxkpost Newcomers
          Thanks for reply,
          Yes I have already made it a group and still nothing??
          • BoxB Offline
            Attach your model or all we can do is guess.
              mxkpost Newcomers
              Ok
              3D Piling~.skp
              • BoxB Offline
                I'm at a bit of a loss as to what to say.
                Your model is all loose geometry, the only component is the scale figure that shows as a nested instance.
                Once Solid inspector has fixed the issues it can there are still holes and overlaps that you need to address manually.
                To get a volume the object needs to be a solid.
                Once fixed and grouped it does show a volume.
                https://i.imgur.com/mRSSVkh.png
