    Plugin UI ??
    3 Posts 2 Posters 220 Views 2 Watching
    • cmeedC
      cmeed
      Hi All,
      Recently I’ve been in the situation of Laptop only, going from two screens to one wasn’t too bad a transition. What it has made me very aware of is how wasteful the tray system / Su UI is! There’s a ton of mismanaged space in all the trays. Trays don’t stay thin. I'm not a fan of popping up trays that have been parked in the side bar that then cover your work. Anyway…
      With the comprehensive plugin by Fredo, ‘LOTBars’, shaping this thought - is it possible to create a new interface?
      Just a thought.
      Is there a discussion that anyone knows of about the tray system that I could look at? UI questions etc.
      Cheers in Advance
      Chris.
        You can shortcut the show/hide tray which is what I do for more real estate.
        I would suggest my PieMenu extension but since they changed the UI handling and continue to do so it becomes a chore supporting it. It works fine in 2022 though.
        As front ending a better UI there's no such luck. RV did share this the other day...
        https://sketchucation.com/forums/viewtopic.php?f=179&t=76663
        Which I tried out and it does work but labour intensive to implement per application.
        • cmeedC
          cmeed
          That Auto Pie Menu is Crazy!!
          I havd a go at Curics Pie Menu but it was too slow. LOTTbars is sooo fast. Not tried yours I'm affraid but indended to until I pursued with Fredos, where I preferred the familier UI resembling SU.
          C
