    Creating a Texture/Material from an Image
    4 Posts 3 Posters 3.6k Views 3 Watching
      At the request of ntxdave, here's the method I used to add an image to the face of a coin. The general method would apply to other materials as well.
      In this case I downloaded an image of the coin as a .jpg file.
      JPG from the web
      Although not strictly necesary for this image I opened it in an image editor. I used PaintDotNet but Gimp, PhotoShop, or any of a number of other options are available. I deleted the white background pixels to make them transparent and cropped the image to tightly fit the coin. Then I saved the result as a PNG file since JPGs do not support transparency.
      PNG with transparent pixels.
      There are a couple of ways to import the image as a material into SketchUp. It can be done in the Materials panel but I prefer to draw a rectangle (or square in this case) with the dimensions of the texture image and use File>Import to import the image and apply it to the face. Make sure to select Use as image as: Texture in the Import window. This method automatically makes the texture the correct size.
      PNG applied to rectangle as a texture.
      After that just use it as you would any other texture.
      Another option is to import the image as an image and then explode it to get a face with the texture on it. You still need to set the size correctly.
      In the case of textures such as the wood grain ones I make, I often have 4 or more images of different planks from the same log. I know what their lengths are but the widths are usually random. I just draw a rectangle to the known length and some random width. Then I use File>Import and import the images as textures and apply them to the rectangle. Repeat until all of the images have been imported and save them to a collection. No need to create a bunch of geometry for that. One rectangle does the job.
      • ntxdaveN
        ntxdave
        Thanks Dave, very nice. πŸ‘ πŸ‘
        Press F1...thank me later
        • Joe WoodJ
          Joe Wood
          Just curious how do you crop a circle?
          Joe Wood
          woodsshop.com/
            The entire image is still rectangular, or square in this case. As I wrote in my post, I made the pixels of the background transparent.
