    SketchUp Diffusion
    7 Posts 3 Posters 2.1k Views 3 Watching
    • Gus RG Offline
      Gus R
      Messing around with Sketchup's AI plugin, Diffusion.
      Video explanation here:
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
      • Gus RG Offline
        Gus R
        • Gus RG Offline
          Gus R
          After the walls fell.
          • marked001M Offline
            marked001
            Gus...would definitely be cool to see the source model, as well. I just installed this too but haven't played with it.
            http://www.revision21vis.com
            instagram: revi21on
            • Gus RG Offline
              Gus R
              I'll look later. You can just do a simple box or rectangular building with a few windows and use that. Under parameters I generally entered:
              Red sky. Dilapidated concrete building in garbage dump.
              • Gus RG Offline
                Gus R
                The first image is just a basic rectangle and ladder with some soldiers I grabbed from 3d warehouse. The other two are just the base models for some recent rendering I posted on here. The wording is important too as noted above. You can either sketch up a box with some windows, use your models or grab something from 3D Warehouse.
                • Mike AmosM Online
                  It is early doors yet, respecting geometry is low on the agenda but obviously can be improved.
                  I had a model rendered where a barbecue was turned into a window/door and another where it was turned into a light source. Early doors though and it does have promise. Question I have is where it leaves dedicated render programs.
                  For me, I would rather have full control over atributes and light elements but I can see it (Diffusion) being very popular.
