SketchUp Diffusion
Messing around with Sketchup's AI plugin, Diffusion.
Video explanation here:
After the walls fell.
Gus...would definitely be cool to see the source model, as well. I just installed this too but haven't played with it.
I'll look later. You can just do a simple box or rectangular building with a few windows and use that. Under parameters I generally entered:
Red sky. Dilapidated concrete building in garbage dump.
The first image is just a basic rectangle and ladder with some soldiers I grabbed from 3d warehouse. The other two are just the base models for some recent rendering I posted on here. The wording is important too as noted above. You can either sketch up a box with some windows, use your models or grab something from 3D Warehouse.
It is early doors yet, respecting geometry is low on the agenda but obviously can be improved.
I had a model rendered where a barbecue was turned into a window/door and another where it was turned into a light source. Early doors though and it does have promise. Question I have is where it leaves dedicated render programs.
For me, I would rather have full control over atributes and light elements but I can see it (Diffusion) being very popular.
