    Ruby and special characters
    10 Posts 4 Posters 1.1k Views 4 Watching
    • A
      areal3d Newcomers
      hi,
      i get ifc-fields from german cad-programs, which have "ä, Ü, " etc. in the ifc-descriptions.
      ho can i handle this in ruby, when i want to check them?
      example:
      iterate key / value...
      if key == "Fläche" then...
      saving this the ruby do not work...
      thanx
      stan
      • TIGT
        In the very first line of your Ruby RB file add this.
        # encoding; UTF-8
        This should ensure your own code is properly formatted.
        Additionally, if needed, to force your 'read' ifc data file's text into the correct encoding try this...
        text_string_read from_ifc_file.force_encoding("UTF-8")
        • artmusicstudioA
          artmusicstudio
          thanx a lot. perfect-:)
          • A
            areal3d Newcomers
            hi tig,
            first : thanx for your help.
            but
            i am doing something wrong.
            i placed the utf info at the very first line (above "Module")
            ` # encoding: UTF-8
            module ZF_ifc
            class ZF_BIM_version
            but i still get
            Error:
            #<SyntaxError: C:/Users/zdene/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/zf_areal3d_bim/areal3d_bim_prg.rb:6743: invalid multibyte char (UTF-8)>
            so i cannot search in keys for german letters (ä,ü,ö).
            in the key of the hash there is an "ä"
            i want to check with ruby, if there is an "ä" in ite key:
            elsif tt[0].to_s.include?("L&#228;nge")
            elsif tt[0].to_s.include?("L&auml;nge")
            elsif tt[0].to_s.include?("Länge")
            i just stick.....
            stan
            • TIGT
              Tells you the line where the error is...
              Have you tried simply copy/pasting the same string with the ä ü ö characters
              into your script, so as to sidestep the issue ?
              e.g.
              an alternative format could be
              elsif tt[0].to_s=~/Länge/
              If the RB is specifically defined as using UTF-8 then it should work...
              • A
                areal3d Newcomers
                the alternativ format is perfectly working !
                thanx a lot for this, i di not know this syntax yet 😄
                stan
                • A
                  areal3d Newcomers
                  hi tig,
                  just a small add to this toppic:
                  situation:
                  i imported a ifc from a german cad with special chatacters "ä,ö,ü..."
                  in the "key" of the ifc-parameter
                  we solved the handling for ruby by using ift-8
                  so far, so good.
                  now i tried to export this file from skp to ifc
                  and reimport ( to see, if my attributes are passed correctly).
                  can it be , that sketchup exports the code of the special character in some special way?
                  in reimport the ifc-key contents the code itself now, not the original special character - somehow...
                  screenshots show the display in the original file and after the re-import.
                  i want to try to detect those codes by ruby again to be able to differ between areas, length and so on.
                  regards
                  stan
                  • TIGT
                    What text encoding does the original ifc file use ?
                    Once you know that you can try to convert the encoding of the final edited string you want to put into that file, encoding it into the appropriate format...
                    https://www.educative.io/answers/how-to-use-the-encoding-class-in-ruby
                    https://www.cloudbees.com/blog/how-ruby-string-encoding-benefits-developers
                    There are lots or resources on the http://www...
                    • A
                      areal3d Newcomers
                      hi tig,
                      ok, if it depends on the encoding of the original file imported to skp, i will have to study it.
                      thanx and merry x-mas!
                      stan
                      • Dan RathbunD
                        Dan Rathbun
                        # encoding; UTF-8
                        This magic comment does not ensure that the code file is saved as UTF-8 w/o BOM.
                        This must be set in whatever code editor is being used.
                        I'm not here much anymore.
