    Lines not changing colour in LayOut
    2 Posts 2 Posters 235 Views 2 Watching
    • K
      katehatherell Newcomers
      I'm trying to change the edge colour of a sofa in LayOut using tags within the SketchUp model tray, and it's not changing. Any ideas why this could be? I've tried it on a couple of test files and it works fine, so I'm not sure why it's not working on this particular file. Is there something that could be over-riding the LayOut line options?
      (The snuggler that I'm trying to change is the little chair in the bottom right hand corner of this screenshot).
        Does the style used for the viewport have Dashes enabled? Does the component containing the geometry actually have the "Snuggler" tag? Is the geometry tagged (it should not be).
        If you share the LayOut file so we can see exactly how you've set it up, we can certainly identify what's going on. If you don't want to make it public, snd it to me via a PM and I will help without sharing the file with the world.
